Hai SACS users,
I got this warning after running the analysis *** WARNING - LOAD LABEL CS01 HAS LOAD ID LOAD NO FOUND. What does it mean?
Hello Fathi Aziz,
We have a wiki for the similar issue.
Please visit the following link.
https://communities.bentley.com/products/offshore/w/wiki/67452/load-condition-not-found-in-s-file
In the datagen the option of the “Combined Loads to Basic Option” is already "Yes" but still the warnings are appeared.
Hi Fathi,Can you share your input and run files so we can duplicate the warnings and propose a solution for it? How to Share MAXSURF/SACS Model Files on the Forum - MAXSURF | MOSES | SACS | OpenWindPower - Wiki - MAXSURF | MOSES | SACS | OpenWindPower - Bentley CommunitiesOr else, you can also raise a service ticket so we can look through it.Regards,Nur
Hi Nurfaiza,
File upload. There are also some other warning which are *** WARNING - SPECIFIED WAVE IS A NEAR BREAKING WAVE OF HEIGHT 8.4916086 M. LOADS WILL BE GENERATED. Please specify the warning and how to solve this warnings. Your help is much appreciated.
Hi Fathi,
Thank you for the files. I have look into it and found that you have defined a Load Label for Load combinations which then output below warnings:Load label only works for load combinations (LOADCN), not load combinations (LCOMB). These warnings didn't affect the results, but if you want to remove it, you can Delete/Comment Block the LOADLB card in the load combinations section.
I ran the files in SACS v23 Minor 1 and found no Breaking wave warnings related. The warning you've received tells you that the specified wave height is near the breaking wave, but the loads will be generated. Feel free to read below Wiki on the Breaking Wave:Does SACS handle breaking waves? - MAXSURF | MOSES | SACS | OpenWindPower - Wiki - MAXSURF | MOSES | SACS | OpenWindPower - Bentley CommunitiesI hope this helps!
Regards,Nur
Answer Verified By: fathi aziz
thanks a lot Nurfaiza
You are welcome, Fathi!
