Dear SACS users,
I got a warning during analysis which are:
*** WARNING: REDESIGN STOPS FOR INVALID GEOMETRY - BETA - OF COMMON JOINT 1138 - CHORD JOINT 1139 - BRACE JOINT 940
*** WARNING Theta(Deg) VALUE OF 29.99 IS OUT OF VALIDITY RANGE FOR COMMON JOINT 199 - CHORD JOINT 425 - BRACE JOINT 126
What does it mean?
Fathi
Hi Fathi,You will be getting a warning message if the joint falls outside the validity range for the connection, but SACS will still perform the analysis using the defined method. The validity checks can be activated by selecting 'VC' in the FTOPT2 line, column 14-15.Regards,Nur
Answer Verified By: fathi aziz
TQ
