How can i correct the orientation of LEG members? When i model Towers with Angle Sections as Leg member, they appear with a wrong orientation and i have to change it manually one by one. And when i change the Beating Angle i have to change all again.Also, when i Design the structure, the Leg members does not design. Appears a symbol of "?" in the reports and does not show Ratios in the graphics mode.
Hello Jose, could you please share your model? Thanks Pankaj
LM_Barranca.rar
Hi, Pankaj. Thanks for your help. File attached.
Which version of the OpenTower Designer you are using. Can you provide your e-mail address.
Im using version 10.02.00.55
my email is jose.casalino@hycgroup.pe
