Major Release – AutoPIPE CONNECT Edition (Version 10.0.0) is Now Available
Bentley AutoPIPE CONNECT Edition (Commercial Release – v10.0.0) is Now Available!
Download from Bentley SELECTservices Online... click here
Download the ReadMe File... click here
To learn more about CONNECT features... click here
Bentley CONNECT Integration
ASME B31.3-2014 Code Update
ASME B31.4-2009 & 2012 Offshore Edition Code Update
ASME B31.8-2014 Code Update (Onshore and Offshore)
Apply ASME Code Case N-755-1 Rules to B31.4 and B31.8 Onshore Codes
Canadian CSA-Z662 2001 & 2015 Additions
Use Local Tee Directions for Class 1 Skewed Tee Moment Summation
Report Inconsistent Non-Linear Code and Non-Code Combinations
Stress Isometric Export
XML Export to be Imported to Plant Design Software Like PDMS
Provide Option to Apply Pressure Correction Factor to User Defined SIF & Flexibility Factor Values
Riser Pipe Pressure
Syncing of Node and Support IDs
Technology Previews
