Hi all,
I'm trying to understand how the Bourdon effect is incorporated in the software. So, I modelled a simple pipeline which consists of a bend with two straight runs. I analyzed the model once without enabling the "Bourdon effect" option and another time with enabling this option. I couldn't find any difference in the stresses or displacements.
I was expecting to find higher stresses on the extrados of the pipe elbow however that was not the case.
I attached a PDF showing the model geometry and loading, and the results from both cases.
Thank you
Hello Diana abdulhameed,
The bourdon effect applies to the pressure extension load cases for the model on bends. Could you confirm that the Calculate Pressure Extension Cases checkbox is checked? To apply the bourdon effect on sustained code compliance stresses, ensure the "Inc. Axial, Pcase in Sus." checkbox in the Result Model Options is checked.
Best
Josh Taylor
Answer Verified By: Mike Dattilio
