Hi Everyone!
I seem to have a problem when I create the iso and data tables using the "createIso" feature of AutoPipe, I hope you can help me.
In my AutoPipe model I have a guide support with different gaps (-Z=1, +Z=2, -X=3 & +X=4) on a vertical pipe.
But when I create the Iso, the data table shows gaps "3" and "4" inverted:
Gap 1 = 1 (OK), Gap 2 = 2 (OK), Gap 3 = 4 (-X should be 3) and Gap 4 = 3 (+X should be 4).
Does anyone has a comment on this? Is there a fix?
I am using AutoPipe Version 09.06.02.06
Thanks.
Hello Daniel,
With a support configured as:
the stress iso table should appear like this:
Note the line, highlighted Yellow, directly under the vertical support,
All gaps are defined correctly regardless of segment direction.
Mike DattilioBentley Product Advantage Group AnalystAutoPIPE Product Line Bentley Systems, Inc.===================================================
Thanks for the reply Mike.
My stress iso table does not appear like that. Please see attached file.
If you need anything else please let me know.
AutoPipe version: 09.06.02.06
Yes it is vertical as far as I know.
Screenshot:
