Ambient temperature/thermal stress range
I have question about ambient temperature and thermal stress range.
I have made the test, I set ambient temperature Amb = -100 deg and set  operating temperature T1=+100 deg.
I have thermal stress from Amb to T1 example 230 MPa.
If I set the Amb=+100 deg and set operating temperature T1= -100 deg.
Then I have thermal stress 238MPa.
Do you know from where this difference come from?
I have been assuming that the stress shall be the same because I have the same delta T.
  • Take a close look at the 'Expansion' value in the Modify -> Operating Pressure and temperature dialog box. If it's checked on Auto, then the program will calculate a value based on the temperature differential. You'll note that the expansion value for +100 deg is not exactly equal to the value for -100 deg. You can over ride this by unchecking the Auto box and entering a constant number.
    Expansion
    This field and the corresponding Auto checkbox are used to input the thermal expansion data for each operating case. For non-standard (NS) materials, the thermal expansion data can be entered and modified, . For standard and code materials, the field is not editable (grayed out) and the corresponding data is automatically retrieved from the material library for the appropriate temperature. For non-standard materials, the default value is zero for new models. For existing models with pipe identifiers defined with code or non-code materials then a new or existing pipe identifier changed to NS material will default to the previous expansion values. To override the automatic library value un-check the Auto option and enter the user-defined data.
    more here:
  • Hi,
    Thank you for your replay. I have additional question. I set the same thermal expansion for both temperature.
    But if I change the temperature at dialog box- General Model options- for example from 0 to 50 deg then thermal stress are change, even if the delta T is the same and linear
    thermal expansion values are the same.
    From where this change come from?
  • Hello Pawel,
    It is not clear what settings you currently have in your model.
    Suggest to add more screen shots to provide a clear picture of what you are trying to accomplish.
    Mike Dattilio
    Bentley Product Advantage Group Analyst
    AutoPIPE Product Line Bentley Systems, Inc.
  • Hi
    Below is clear explanation with snaps.
    I have operating temperature T1 -100 deg and T2 +100 deg (according to snap below).
    I used the same linear thermal expansion for both temperatures as was stated above:
    I made two test,
    First one with ambient temperature/installation temperature equal to 0 deg:
    then the thermal stress are 306.69 MPa at point A00:
    Second test is with ambient temperature/installation temperature equal to 50 deg:
    then the thermal stress are 302 MPa at point A00:
    From where this small difference come from in computes thermal stress if we have the same delta T and same linear thermal expansion factor.
  • Hello Pawel,
    Review the pipe properties after changing the ambient temperature (specifically the Long Mod, Hoop mod, etc..). These values may change depending on ambient temp.
    Mike Dattilio
