Normally gaps are provided for supports either left/right & up/down. But while extracting report for supports, it shows Gap1 & Gap2 only. We want know the global direction of the gap for the particular support. Is there any option to get? kindly explain.
Thanks in advance.
Hello Gobinath,
You are correct that the model input listing Support Data Listing sub-report has 2 columns labeled Gap 1 and Gap 2:
The user can look to the component listing for greater details on the support direction.
Remember that the reports would have to accommodate both supports on global axis and skewed axis. Please post your suggestions on how to best report supports gaps that are both on Global and Skewed axis in only 2 column but can have multiple rows of data for each support as shown above.
We look forward to your comments.
Mike DattilioBentley Product Advantage Group AnalystAutoPIPE Product Line Bentley Systems, Inc.===================================================
