Is component rotation limited to 4 digits or can it be expanded?
I'm working on a model and using the AutoCAD DXF feature to import into a model. The models are rotated by a 9 digit number, e.g. -23.312345678.
When I try to rotate the model around a point, I make sure to input all 9 digits but when I hit tab AutoPIPE changes it to a simple 3 digit number. However the max number of characters I can input is 4 characters, resulting in (-23.3).
A quick test shows that rotating at -23.300 results in the same dimensions as -23.312345678, which makes me believe that those extra digits are dropped.
Is there a way to rotate it with a more fine-tune approach?
Thank you.
  • Hello Timothy,
    You are correct that the Rotating angles is limited to only 5 characters (i.e. decimal, number, sign). I have logged an enhancement to increase this value.
              Enhancement 134265: Increase the number of character input for Rotate
    In the meantime, one work around, perform 2 rotations:
    Rotation Angles (in degrees)   : X-Axis: -23.0   Y-Axis: 0.000   Z-Axis: 0.000
    Rotation Angles (in degrees)   : X-Axis: -.312   Y-Axis: 0.000   Z-Axis: 0.000
    thus adding at least 2 more digits to your accuracy.
    Mike Dattilio
    Bentley Product Advantage Group Analyst
    AutoPIPE Product Line Bentley Systems, Inc.
    AutoPIPE On-Demand Training CLICK HERE
    YouTube- Bentley Pipe Stress - Subscribe
    LinkedIN   CLICK HERE
    Answer Verified By: Timothy Phan
  • I appreciate the response Mike and the increase in accuracy for now. I'll look forward to seeing this in the next version.
    Best regards,
    Tim
  • Hello Timothy,
    I cannot guaranty that this will make the next version, but will be in a future release. Just not sure exactly when.
    Mike Dattilio
