HelloWhen I export the model to Autocad DXF I see that the valve symbol is not centered between the flanges. There is any solution at this problem?
Ivan
Hello Ivan. At this time, there is no solution other than manual work in AutoCAD. A defect has been logged for this issue to be fixed in a future release.
This has now been fixed and will be implemented in Version 11.2.
