water hammer effect on beam members
Command Reference > "Adding, modifying, and deleting beams" states that beam members cannot be subjected to steam/water hammer transient effects. Is this saying that you cannot apply water hammer force time history loads directly to a beam point? Or is it completely disallowing the use of beams in a force time history analysis? Thanks in advance for any clarification you can give me. I'm hoping it will be possible to construct pipe supports out of beam members for calculations that include water hammer loads.
  • Hello Tim,
    When specifying a Time history one must enter a path for the Steam / Water hammer transient effects to be applied to, see image below:
    This note was intended to mean that one cannot use a beam as part of this Steam / Water hammer transient path. However, if supports are connected from a piping system to the beam structure. Then, Yes the load from the Steam / Water hammer load case would be transmitted from the pipe to the beam structure.
    Mike Dattilio
    Bentley Product Advantage Group Analyst
    AutoPIPE Product Line Bentley Systems, Inc.
    AutoPIPE On-Demand Training CLICK HERE
    YouTube- Bentley Pipe Stress - Subscribe
    LinkedIN   CLICK HERE
    Answer Verified By: Tim Barta
