Hello!
We can use A335-P92 material in AutoPIPE, but I don't know where the material properties come from.
I can find only thermal expansion coefficient and allowable stress from ASME B31.1 and ASME Sec II, Part D respectively. But they are a little bit different from the values in AutoPIPE.
Even, I can't find elastic modulus of A335-P92 in code.
What is the basis of A335-P92 material properties in AutoPIPE?
SA335 P92
(9Cr-2W-0.6Mo-0.25V)
Pipe Temperature
Linear Thermal expansion co-efficient,α,
mm/m
Hot Elastic Modulus,
Eh,
Kg/cm2x10^6
Allowable Hot Stress,
Sh
Kg/cm2
As Per AutoPipe
603 °C
7.5
1.27
760.5
As Per ASME B31.1,2014
Not Available
760.1
As Per ASME Sec II, Part D
7.3
Thank you!
Hello Hyukchan Kwon,
See WIKI here , example #3, for details on how to find out this information from AutoPIPE help. It is a very simple process. To answer your question directly for material library = B311-14:
From the Code Dependent Pipe Materials, find the following:
Use UC1, and open the same code year Standard Pipe Material library to find the following:
Answer:
Yield Stress values were taken from ASME B31.1 - 2014Ultimate Stress values were taken from ASME B31.1 - 2014Allowable Stress value were taken from ASME B31.1 - 2014Thermal Expan. Coef. values were taken from T92/P92 Book, Vallourec & Mannesmann Tubes (2000)Young's Modulus values were taken from T92/P92 Book, Vallourec & Mannesmann Tubes (2000)
Mike DattilioBentley Systems Design AnalystDesign Engineering Analysis group===================================================
Answer Verified By: Mike Dattilio
Hi Mike,
But there seems to be a problem !
The reference for thermal expansion as well as "Elastic Modulus" from T92/P92 Book, Vallourec & Mannesmann Tubes (2000) seems to be superseded by article PWR2005-50110 (ASME Power) 2005 article.
And there is a huge difference in particularly the Hot Modulus of Elasticity huge should be much lower than the ones of Vallourec book.
With best regards,
Swagatam
