Hello Everybody, One of my company Customer want us to provide piping pulsation analysis for gas compressor station where theoretically pulsation sources are two centrifugal compressors. I know that Puls software is not designed for piping pulsation with centrifugal compressors. Centrifugal compressors particularly in these times should not be considered as pulsation pressure source, however it has been assumed and defined by the Customer that these pulsation sources should not exceed 10% of maximum pulsation value peak to peak based on API 618 in Puls software for given rpm of compressors? 1.Based on requirement of 10% how exactly should I define the pulsation source to perform pressure and force simulation vs frequency in Puls? Would 10% of the pressure pulsation curve based on API 618 be my input, and having that I should calculate forces vs frequecy for each node then the harmonics would be imported to Autopipe (harmonics described by damping of ~2%, frequency for the 1-st, 2-nd, and 3-rd harmonics with phases and forces acting in different direction)? Can I find any example in Bentley resources that could show me practical way of solving problem mentioned above? Given data:
Suction side – 4MPa
Discharge side – 6,5MPa
Methane gas flow – 140 thousand m3/h
2. If the piping model in Puls will have less than 400 nodes for both suction and discharge lines it seems to me that option 1 of Puls software be good enough to make pressure and dynamic forces acoustic simulations (with two centrifugal compressors) ? Am I correct thinking so?
Best Regards
Robert Augustyn
In document nr.1 at WIKI (PULS issues) it is stated: [cyt] While there are similarities, there are also basic differences between acoustic analysis of centrifugal and reciprocating compressor piping. The fundamental approach of avoiding coincidence between excitation and resonant response is common to both types of piping systems. Pulsation sources, however, are treated very differently. The role of the centrifugal compressor in acoustic analysis is also very different from the role of the reciprocating compressor. For example, centrifugal compressors are modelled as specialized elements that connect the suction and discharge piping systems.
Pulsation sources in centrifugal compressor piping are flow generated and occur at all locations where the flow separates from the pipe wall. In practice, only tees and control valves generate significant pulsation. Flow generated sources occur simultaneously, however, for design stage analysis each source is modelled individually. Further, and in contrast to reciprocating compressor piping, effective solutions to flow generated pulsation deal directly with the pulsation source.
The source modelling methods described in this paper have been presented as manual calculation procedures so they may be used by all designers who have access to an acoustic simulator. To simplify and reduce design effort, each of the methods described has been incorporated into PULS, the acoustic simulator developed by NHRC and AGTD.
Finally, the influence of mechanical response on acoustic design, and vice versa, is very important. This is clearly demonstrated by the use of closely linked mechanical and acoustical guidelines. For example, the minimum mechanical natural frequency guideline and the acoustic shaking force guideline were developed in unison for design stage analysis based on designers' field and office experience.
I’d like to refer to the sentences written above in bold and underlined and ask three questions?.
