48.pcf
Could anyone explain why I can not import 48.pcf file created in AutCAD 3D Plant (file atatched). There is either the error that says: ntl file can not be open or the import proces aborted.
Bob
Hello Mr. Augustyn,
Why don't you send this file directly to tomasz.bakalarz@softdesk.pl (tel. 512206995) who is our expert in this kind of problems? I believe that you generate it from Autodesk Plant 3D (as you gave up OpenPlant implementation) and it requires good class mapping.
Best,
Maciej Rydlewicz
Best regards,
Maciej Rydlewicz, PhD Eng.
maciej.rydlewicz@softdesk.pl
+48 512206994
Thank you Mr. Rydlewicz for your response.I will send this file to tomasz.bakalarz@softdesk.pl as you suggest.I appreciate your support.RegardsWojciech Augustyn
Thank you Mike for your response. I will send this file to tomasz.bakalarz@softdesk.pl (an expert in this kind of problems)as recommended Maciej Rydlewicz. If something goes wrong I will follow your instructions.I appreciate your support a lot.RegardsBob Augustyn
Answer Verified By: Mike Dattilio
