Could somebody to help check this problem with the OPIM stress iso ? The dimension of the piping had been rotated. How to correct it in the OPIM ? Thanks a lot.
Dear Jianwei Hong,
I believe this is from Application AutoPipe + Openplant Isometrics Manager.
We are moving this to corresponding forum for quick help.
HTH,
Rahul Kumar
Dear Mr. Kumar:
You are right. It's the question about the AutoPipe + Openplant Isometrics Manager. Thanks for your help.
Regards.
Hello Jianwei Hong,
Can you please upload a sample model for me to review? If not due to security reasons, please log a Service Request and upload your model to the SR.
Mike DattilioBentley Systems Design AnalystDesign Engineering Analysis group===================================================
A3BORD.dgn
Dear Dattilio:
Thanks for your reply. I think the problem is at the .dgn. It's only problem at the A3BORD. We just try to change the frame information at the A3BORD. When we using the others drawing frame files such as A1BORD.dgn ,A2BORD.dgn that will be fine. And we had reinstalled autopipe and then the thing is ok.
Best regards
Good to hear all is well again. According to your reply above the fix was to reinstall the program. However it does not help not knowing exactly what was the issue that caused the problem. If this happens in the future, try to create an exact steps to repeat so I can send it to the development to for evaluation. Without that information, the development team has nothing to go on to fix an issue.
Have a great day.
Answer Verified By: Mike Dattilio
