NTL Import/Export changes NTL file
NTL file has been exported from AutoPIPE Advanced 11.00.00.22. This is then imported into AutoPIPE Advanced 11.04.00.10 on a different computer and subsequently re-exported to NTL format.
Comparison of the original NTL file and the new exported NTL file show a number of minor differences which can be explained by consideration of the Card Reference. However the SPA1 card shows a large increase in the Dry Unit Weight of the soil (increased by ~16x) which I do not understand as there doesn't appear to be a change within the card definition here.
L_spool_soils_Orig.TXTL_spool_soils_11.04Export.TXT
Any help on this matter would be appreciated.
Derek
