Please explain me the what is the general stress calculation and what is the code compliance calculation, Is these the separate concepts? And which concept is usually used for analyzing stress?
Difference between general stress and code compliance
  • Hello Thang,
    The user must select a Piping code to analyse the model too. After analyzing the model, the user can view results from a multitude of sub-reports. You are asking about the difference between the General Stress & Code Compliance sub reports.
    To better understand the differences best to look at the actual calculations that are being performed.
    As indicated, Code Compliance calculations are based on calculations required by the selected code. Where, as mentioned in the above help locations, General Stress Calculations are based on total stress calculations which are generally not required by most piping codes. You will notice that the General Stress Calculations are not compared against an Allowable.
    Mike Dattilio
    Bentley Systems Design Analyst
    Design Engineering Analysis group
    Answer Verified By: Mike Dattilio
  • I got the answer from you and thank you very much. Now I can define separately 2 these concepts
