Hello, I have a model that needs to be analized with B31.3, but I have a pipe that is B31.8. How can I have more than 1 piping code in the model?, I have the latest version
Good Day to you Aaron,
HVN is correct, as of Nov 2019, AutoPIPE cannot analyze a model with more than one piping code. This request has been logged (109582). and should be available in a future version of the program.
Workaround, create 2 models, only difference is piping code selection, analyze the model, highlight the piping under consideration for the indicated piping code, and use "Limit results to highlighted points" feature when creating an output report.
Mike DattilioBentley Systems Design AnalystDesign Engineering Analysis group===================================================
Answer Verified By: Mike Dattilio
