The moment in GTP at turbine exhaust nozzle is very high in Z direction, I must consider the various condition such as: temperature, pressure and gravity. I tried and error many times and the current situation is the best until now, but the GTP also exceeds the allowable value, I think the main cause is Thermal. Please tell me how can I do for reducing the load and moment in this case
Good day to you Thang,
Suggest that you work with a spring manufacture to specify the correct spring support near the anchor. In addition, suggest that you use AutoPIPE's spring hanger selection command with the anchor released in the vertical direction.
See AutoPIPE help for details on the above mentioned commands. Also see the Learning path videos here (under 4. Intermediate Modeling and Analysis Using AutoPIPE> Spring Selection in AutoPIPE PDF and Dataset Download).
Mike DattilioBentley Systems Design AnalystDesign Engineering Analysis group===================================================
