How to define two different wall thicknesses for reduction tees using "COMPONENT-ATTRUBUTE4" parameter in PCF-format file?
When this parameter for such tee's is omitted the default values of thicknesses (OD/4) are assigned and must be in AutoPIPE corrected after import of PCF file.
Ok, we can define two different outside diameters for main and branch pipe in tee, but normally we have also two different wall thicknesses associated with those tees. In PCF-format file I see only a possibility to define only one thickness for whole tee using COMPONENT-ATTRIBUTE4 and here's the problem. After importing a PCF model into AutoPIPE all reducing tees must be manually corrected.
