Hi!
For some reason when I try to import my AutoPIPE pipelink file into STAAD.pro it doesn't import correctly.
I don't get any error messages, but my STAAD window (piping tab) only shows a weird line instead of my model and the piping (see image!!!)
I don't think that STAAD is the issue because it imports other pipelink files correctly, but I think I may have somehow corrupted my AutoPIPE file?
This is such a bizarre issue, any help would be INCREDIBLY appreciated!
Good day to you Lauren,
This looks like a coordinate issue. Are you using the same coordinates in both AutoPIPE and STAAD?
Do you have the same Coordinate directions, X,Y,Z orientation?
Mike DattilioBentley Systems Design AnalystDesign Engineering Analysis group===================================================
