i have question about the direction of force & moments. The pipe force-moments output will have same direction (whether positive or negative) as the pipe displacement at a node or not in Autopipe? i have checked and sometimes the direction between these two are not the same. As what i understand, the force and displacement should be in the same direction.
Good Day to you Fifah,
It all depends on the direction of the segment and exposed cross section where the calculations are performed.
Please see the following AutoPIPE help section: Help ribbon> Contents button> Contents Tab> Reference Information> Results Interpretation> Pipe Forces and Moments: Global Option.
You can perform this experiment yourself:
Notice the values and the directions for each report. Displacement remain unchanged in both direction and magnitude. However, Forces and moments for each segment directions have changed but not their magnitudes.
Again, all depends on the segment direction and exposed face where calculations are performed.
Mike DattilioBentley Systems Design AnalystDesign Engineering Analysis group===================================================
Answer Verified By: Fifah Rashid
Thanks Mike for your reply. it really helps!
