We are using Autopipe version 12.00.00.16. For this version, Autopipe Output report Equation numbers do not align with ASME Section III Subsection NC 1980 E 1980 Addenda. e.g. equation number for sustained stresses in ASME NC E1980S1980 is Eq. 9, while the Autopipe output report list this as Equation 8. Similarly other equation numbers do not align. Is there a way to achieve this alignment.
Good day to you Ashish,
AutoPIPE's development team has investigated this issue and agree that you have valid point. The have logged 2 items to be fixed in an upcoming release of the program:
1. ASME NC/ND 1980+1980 Sum. add.: Equation numbers in stress summary are not in sync with the code (1081432)
2. Update Program help stress Equations for ASME NC/ND 1980 and earlier editions (1081453)
Mike DattilioBentley Systems Design AnalystDesign Engineering Analysis group===================================================
