Does Autopipe include flanges checks for standard flanges to ASME V111 div 2, eq 4.16.19 (code case 2901)?
I have run the ASME Section VIII 2010, Division 2 checks but can not see where this refers to equation 4.16.19. (I assume this will be future feature as this equation is new in the 2019 code)
Hello kevink,
Thank you for your question. You are correct that this will be a future feature. As you've mentioned, AutoPIPE's flange calculations for ASME VIII division 2 is the 2010 edition, which did not include equation 4.16.19 at the time. I have logged an enhancement request (1083257) to add this calculation in a later release of the product.
BestJoshua Taylor
