regards the subject, i searched for an answer to this problem and as far as i understood, either ways, the program will take the ratio of 14. My concern is about changing this value, so i can enter it manually so i get the right results.
Does it make sense to take a ratio of 14 for , in my case. a real ratio of 30?
Good day to you Mahmoud Obaid,
Please see WIKI page here for typical messages. In this case the text box label was "Bentley AutoPIPE", select the appropriate hyperlink from the WIKI page link. Then scroll down the page to find "H/D is greater than 14.0", select the hyperlink to see a WIKI on why this message would be displayed.
Therefore regardless of actual values, you are being notified that a max value will be used by the program.
Mike DattilioBentley Systems Design AnalystDesign Engineering Analysis group===================================================
