Using version 11.2, b31.4-2016 Code
Tried to Modify and to Insert Soil Properties to add Overburden loads for a section of pipe.
Every time it gives me this warning, but doesn't say which value it's referencing. I believe it's k2, but it's within the range.
Also, the warning won't go away. I have to use Task Manager to close AP.
Tried deleting everything but .dat file, same results.
Good day to you Lone Star Expat,
Please see WIKI page here for typical messages. In this case the text box label was "Bentley AutoPIPE", select the appropriate hyperlink from the WIKI page link. Then scroll down the page to find "The value should be in range 0.010 to 10.000", select the hyperlink to see a WIKI on why this message would be displayed.
After you update the Soil overburden values, the message should not appear.
What version are you using? (8 digit number, help> About)
Mike DattilioBentley Systems Design AnalystDesign Engineering Analysis group===================================================
