Hi Everyone,
I have a query regarding a clamp support in vertical pipe. I am sharing a picture showing the support type. The clamp is sitting on the grating.
I need expert suggestion on this kind of support.
Thank you
Rasel
Apply a line stop or a Y stop
Answer Verified By: Rasel Sultan
Good day to you Rasel,
Kevink comment is a 100% correct.
Thank you for your time and efforts.
Regards,Mike DattilioBentley Product Advantage Group Senior AnalystBentley Systems Inc=============================================================================
NEW Bentley AutoPIPE v12.3
AutoPIPE's New Feature:Support Optimizer
Working From Remote Location/ Home with AutoPIPE
AutoPIPE TrainingWebinarHelp
Note: Licensing: (PDF file)For all Bentley V8i versions and lower.Bentley SELECTServer will bedeprecated at the end of Dec 2020
Answer Verified By: Mike Dattilio
Thank you KevinK and Mike for your help.
