I'm calculating a piping system with ASME III ND, 2017 Edition. However, when I run the Flange Check analysis using ASME III App. XI, it uses the 2010 edition. Can I choose which edition is used?
Good day to you Santiago,
As of April 2020, AutoPIPE Flange analysis method is hard coded with only a single code year; as indicated on the Flange analysis output report. An enhancement has been logged (1083257) to add this feature into a future version of the program.
Suggest that you add your request to the IDEAS page here.
Regards,Mike DattilioBentley Product Advantage Group Senior AnalystBentley Systems Inc=============================================================================
NEW Bentley AutoPIPE v12.3
AutoPIPE's New Feature:Support Optimizer
Working From Remote Location/ Home with AutoPIPE
AutoPIPE TrainingWebinarHelp
Note: Licensing: (PDF file)For all Bentley V8i versions and lower.Bentley SELECTServer will bedeprecated at the end of Dec 2020
Answer Verified By: Mike Dattilio
