I have a couple of questions about SAM
1. Why are the beam anchor points listed in “Seismic Anchor Movements and Displacements” but not included in “SAM / MSRS SUPPORT GROUPS” in input file? See highlighted in red below. Does this mean the SAMs at the beam points are not included in the seismic analysis ? See page 195 to 196 of .RPT (input) file.
2. There is only one SAM case defined in the model which is S1, why is SAM2 showed in the output ? Is SAM2 for S1 case Group 2 ?
Geping
I have uploaded two files:
RM301 DRS AND D2O LINES 20200218.RPT
RM301 DRS AND D2O LINES 20200218.OUT
Hello Geping,
You are correct anchors located on beam components are not printed in the ""SAM / MSRS SUPPORT GROUP" sub-report. I have logged an enhancement and an Service Request to address this issue (1100746).
Regards,Mike DattilioBentley Product Advantage Group Senior AnalystBentley Systems Inc=============================================================================
AutoPIPE's New Feature:Support Optimizer
Working From Remote Location/ Home with AutoPIPE
AutoPIPE TrainingWebinarHelp
Note: Licensing: (PDF file)For all Bentley V8i versions and lower.Bentley SELECTServer will be deprecated
Answer Verified By: Mike Dattilio
