Hi All
I am an occasional user and keep finding menu items that are missing or have moved.
With help from this forum I now know where the menu search field (binoculars) is located.
But this doesn't seem to include any entries for the Flexibility Factor on elbows.
Can someone point me in the direction please?
Phil
Forget that I have just found it in the main data input form for the nozzle location. Could have sworn that was under Xtra Data previously.
Answer Verified By: Phil Scull
Good day to you Phil
Glad to know that you were able to find what you were looking for.
You are correct the binoculars search utility would not find "Flexibility Factor ". The binoculars feature is a "Command Search Utility".
Appears that you were looking for a specific setting on a command dialog. Doing a search in AutoPIPE help would quickly shown that flexibility factors on:
1. Bend dialog - Bend (Modify > Piping Components > Bend)
2. Nozzle dialog - Nozzle (Modify > Piping Components > Nozzle)
3. Flexible Joint dialog - Flexible Joint (Modify > Piping Components > Flexible Joint)
4. Flexible anchor - Flexible Joint (Modify > Piping Components > Flexible Joint)
Regards, Mike Dattilio Bentley Product Advantage Group Senior AnalystBentley Systems Inc=============================================================================
Answer Verified By: Mike Dattilio
