Autopipe Connect Version 12.02.00.14.
I like to work with the input grid turned off (for speed) but the grid turns on and refreshes automatically every time I delete a support or a node. This did not happen before (in previous versions such as 09.06.02.06). Is there a fix for this?
Hello Daniel,
Please open the Grids settings dialog (Tools > Tools > Settings > Grids) and uncheck the "Show input grid after opening the program (Default = ON)" box to be disabled. Then restart AutoPIPE and try to see if this resolved the issue.
Remember to add any new ideas that you may have about AutoPIPE to our new WIKI here.
Regards,Mike DattilioBentley Product Advantage Group Senior AnalystBentley Systems Inc=============================================================================
NEW Bentley AutoPIPE v12.3
What's your idea
AutoPIPE's New Feature:Support Optimizer
Working From Remote Location/ Home with AutoPIPE
AutoPIPE TrainingWebinarHelp
Note: Licensing: (PDF file)For all Bentley V8i versions and lower.Bentley SELECTServer will be deprecated
Answer Verified By: Daniel Salas
This seems to work, thanks.
This worked for me as well, thank you. Any idea why this is happening and will the issue be fixed in an upcoming update?
