how to add extended component in output report AUTOPIPE V 12.3
Please find the attached the extended component in AUTOPIPE v 12.2 version.
I'll be thankful for any assistance and suggestions
PDF
Hello Sridhar,
All of the information once available in the "Extended Component" has been replaced by multiple sub-reports in AutoPIPE.
To access them select the Results Ribbon, press the input listing icon to open the dialog.
Once the dialog is opened, move sub-reports from the left column to the right column as needed using the control arrows located between the columns. Also enable check boxes at the top of the column as needed. Pressing OK will create the model input listing.
In order to add input listing into the output report, select the "Output Report" button icon to start the commend. Once the dialog appears, enable the "Model Listing" box to include the current input listing report into the output report. Again add additional sub reports from the Left column to the Right column and press OK button.
Remember to add any new ideas that you may have about AutoPIPE to our new WIKI here.
Regards,Mike DattilioBentley Product Advantage Group Senior AnalystBentley Systems Inc=============================================================================
NEW Bentley AutoPIPE v12.3
What's your idea
AutoPIPE's New Feature:Support Optimizer
Working From Remote Location/ Home with AutoPIPE
AutoPIPE TrainingWebinarHelp
Note: Licensing: (PDF file)For all Bentley V8i versions and lower.Bentley SELECTServer will be deprecated
Hello Mike Dattilio,
Thank u so much for your reply, I tried want you said above, but its not coming extended component
(Input list -like pipe node 10 to 20 -1000 mm,
20 to 30 -550 mm for your reference please find attached the file ) that details are not coming.
Can You please generate output report and sent to us
Good day to you Sridhar,
The old Extended Component sub-report was in a paragraph form that many found difficult to read. As you know the data from this old sub-report was separated out into multiple sub-table reports starting in v.12.03. See Coordinate Data Listing sub-report for a listing of node points and their location. The only information missing is the delta offset between points, correct? Is there anything else you like see added to this table?
Regards, Mike Dattilio Bentley Product Advantage Group Senior AnalystBentley Systems Inc=============================================================================
Mike Dattilio, estas equivocado para quienes están inmersos piping stress no se nos dificulta entender el reporte "extended component" y al contrario nos permite realizar la verificación del modelo de una manera rápida y concisa. Y sobre este tema mi empresa esta teniendo problemas con nuestro cliente PEMEX por no presentarles el reporte "extended component". Por lo que les solicitamos como requerimiento no como sugerencia reactivar este reporte. n caso contrario les solicitamos un reporte técnico del porque ya no presentamos este reporte y no solo la escusa de "that many found difficult to read".
Quedo en espera de su pronta respuesta y solución. En el caso de que tu no seas el indicado para solucionar esto favor de indicarnos la logística para lograr lo solicitado.
saludos
Hello AutoPIPE Presco,
I would like to continue this conversation, please log a Service Request and will be glad to following up with communications through the SR manager.
Regards, Mike Dattilio Design Analysis Engineering Group Senior AnalystBentley Systems Inc=============================================================================
Hello All,
Anyone who also believes that the extended data report should be reinstated, please log a service request, providing details on how you use the extended component report in your review process. Also, why using the AutoPIPE on screen results tools are no substitute for the extended component report.
