AutoPipe give me error of instable system and asking to add support in node in RZ although I am sure that node has rigid ends, the error is still exists even if I put rigid anchor at that node.
Good day to you MIbrahim
When the program displays an information dialog. use WIKI here to help address the issue, in your case I believe that you are talking about:
E801-1: FATAL ERROR: Unstable System - error message in AutoPIPE
Therefore, select the Error hyperlink on the WIKI page mentioned above, then search for "E801-1: FATAL ERROR:..." message in the listing and select that hyperlink.
There are a number of reasons that would cause this error message to appear. I have posted detailed information to help tract down the most frequent reasons. Please review to determine if one may fix your model.
Regards,Mike DattilioBentley Product Advantage Group Senior AnalystBentley Systems Inc=============================================================================
NEW Bentley AutoPIPE v12.3
What's your idea
AutoPIPE's New Feature:Support Optimizer
Working From Remote Location/ Home with AutoPIPE
AutoPIPE TrainingWebinarHelp
Note: Licensing: (PDF file)For all Bentley V8i versions and lower.Bentley SELECTServer will be deprecated
