How to select which load combinations are used for flange check?
Non-code combinations are randomly selected for inclusion in the flange analysis, and would like to select load cases for the flange analysis. I have tried following the guide linked below; however, I do not have the "Load*" tab as shown in the guide.
https://communities.bentley.com/products/pipe_stress_analysis/w/pipe_stress_analysis__wiki/18326/q-what-load-case-combinations-are-added-to-the-flange-analysis-dialog-what-is-the-selection-criteria
I have AutoPIPE Standard Version 11.04.00.10, is the "Load*" tab only included with advanced or nuclear? Below is my flange analysis window.
