I have a pressure network in civil 3D of a district cooling network and I need to make stress analysis for this network with AutoPIPE.
i need to know how the workflow will go through this process
Good day to you Abdelrhman Qandeel ,
See WIKI here.
If a specific format is not listed then AutoPIPE cannot import that file type directly. Instead use another software that is compatible to open your model file format and save it to a format that AutoPIPE can open.
Regards,Mike DattilioBentley Product Advantage Group Senior AnalystBentley Systems Inc=============================================================================
AutoPIPE's New Feature:Support Optimizer
Working From Remote Location/ Home with AutoPIPE
AutoPIPE TrainingWebinarHelp
Note: Licensing: (PDF file)For all Bentley V8i versions and lower.Bentley SELECTServer will be deprecated
Answer Verified By: Mike Dattilio
