Please provide modelling details for HDPE pipe properties (ASME Code, Yield Stress, Ult stress, etc.) and Elbow modelling
Good day to you Wayne,
See wiki here for modeling an elbow. select the hyperlink for:
1. Piping > b. Different Types of PIPING Components (i.e Tee, Bend, Reducer, Flange, Flexible / Expansion Joint, Slip Joint, Ball and Socket, Valve, etc..)
On the next page, starting from the top, see AutoPIPE help context on how to model a bend. After reading and performing those exercises, read further down the page and select hyperlink for:
>a. Bends
Back to the original hyperlink at the top of the page for Modeling Approaches,
1. Piping> c. Non-metallic Plastic Piping (i.e. Plastic, PVC, PP, PPR, HDPE, PE, FRP, GRP, etc.)
Select hyperlinks as required.
Regards,Mike DattilioBentley Product Advantage Group Senior AnalystBentley Systems Inc=============================================================================
AutoPIPE's New Feature:Support Optimizer
Working From Remote Location/ Home with AutoPIPE
AutoPIPE TrainingWebinarHelp
Note: Licensing: (PDF file)For all Bentley V8i versions and lower.Bentley SELECTServer will be deprecated
