For example: separate to 2 part: one includes OP1 case and Hydrotest case, the other includes only OP1 Please refer to the image for more detailRed marked zone is for OP1 and Hydrotest case, not red marked zone is for OP1 only
Please help me on this issue Thank you very much
At this time, Sept 2020, AutoPIPE's analysis sets cannot be assigned based on segments. Another words, if model contains segment A,B,C, one is not able to assign segment A & B to Analysis set 1 and segment B to Analysis set 2.
However, there is one exception, AutoPIPE performs an hydrotest as an individual analysis set, where the user can assign which segments on the Segment tab of the input grid to have a hydrotest load applied.
Regards, Mike Dattilio Bentley Product Advantage Group Senior AnalystBentley Systems Inc=============================================================================
Answer Verified By: Mike Dattilio
Thank you for your answer
