How to import pipelink.db files back into AutoPIPE?
With the new Staad.Pro Connect Edition, the pipelink files are created in a different database. So when I initially import a pipelink file into the staad.pro, I had to run PipelinkDatabaseConverter.exe to convert the .pipelink files into pipelink.db files.
However, to export the Staad.Pro information back into AutoPIPE, what method should I use? because the new staad.pro generates a .pipelink.db file and I can't insert that file back into AutoPIPE.
