I have run some load cases for a Subsea Manifold with Anchor Supports attached to the piping. When I export the model to Staad via Pipelink, my colleague does not see the same load reactions in STAAD that I do in AutoPipe (in some cases, no loads at all).
For Instance, this is the STAAD import. It has no reactions in case Thermal 1 even though I do in AutoPipe.
Also, the loads in case Thermal 2 do not match what I have as anchor support reactions in AutoPipe for Thermal 2.
Thank you!
Casey
Good day to you Casey,
I am not able to provide a definitive answer without reviewing both the STAAD model and AutoPIPE model. Therefore, please log a service request and add the AutoPIPE APC file with the STAAD file. File it against STAAD product because that is the application reading the information differently than produced.
Regards, Mike Dattilio Design Analysis Engineering Group Senior AnalystBentley Systems Inc=============================================================================
