There are seven steps outlined under the Time History Analysis heading in the "Missing Mass and ZPA Correction" help topic for applying the ZPA option to force time history analysis. The discussion uses terminology that isn't defined in the help file. I would appreciate an explanation or example to clarify the seven-step process - in particular, the first four steps are unclear, leading to questions such as the following:
Hi TIm,
It appears you are using an older version of AutoPIPE? You have a question about TIH here but in the latest release, Version 12.04.00.13, this is called the THP for TIme History Profile. I would recommend updating AutoPIPE. Please see the responses to your questions below.
Here’s an example of the THP file. The loads are being summed from here, where there is no specified direction. The direction is later applied in the THL file.
What this approach is trying to do is identify a value of load that can be used for ZPA check. For time history you can do this two ways.
Yes, Steps 1 and 2 are both considering the time steps, so they are looking at the discretized loads.
Yes.
Please let me know if this answers all of your questions.
Jessica Alegre
Hi Jessica,
Thanks for replying. Yes, I am using an older version of AutoPIPE (v10) but we are in the process of upgrading.
I still need some clarification on the ZPA process that you described:
With respect to the first bullet point in our discussion, what loads are being summed? The help file says ZPA Step 1 is "Sum all TIH loads associated with a node by sampling at the analysis time step." Two of the possibilities I have at the moment are that
If I could understand the above, it would help me with the whole process. I have been trying to make sure we have a good knowledge of what the software is doing when we run an analysis, so thank you for your help.
