I have a water network project PVC pipe material. However, we will do the water hammer study on "Hammer" to add the appropriate vessel and relief valves. ِAlso a pipe stress analysis is needed, however I need to extract data from the hammer simulation to added in Autopipe.
What type of data needed to be extracted is it TIH data but the hammer cannot extract such data.? or just the maximum forces at the node as concentrated forces? the maximum forces with the corresponding time and add them as a time history analysis? however how to extract such data ?
kindly advice
Good day to you Tarek,
It would appear that you are new to our Bentley Community pages, Please note that you can search and drive into topics like this.
From the WIKI tile above,
1. Select the WIKI tile
2. Select the hyperlink for AutoPIPE Wiki
3. On the left is a column, select "Bentley AutoPIPE"
4. Scroll down the column and select "Import and Export "
5. Again, scroll down a little further and select "Imported related issues"
6. On the right is a listing of application and related file types that can be imported into AutoPIPE. scroll down the listing to "f. Bentley HAMMER"
This WIKI will answer your questions on AutoPIPE and Hammer integration
Regards, Mike Dattilio Design Analysis Engineering Group Senior AnalystBentley Systems Inc=============================================================================
thank you for the reply,
I saw this I need to take it and insert it manually.
but in hammer, all the data start from 0 seconds for each node, and in the Autopipe when inserting the data they need "start time" for each point.
if this is the correct way, how we get the start time for each node in Hammer?
