I get the following message when i modeling a 4 inches STD pipe class 300, why is that?
*** GLOBAL CONSISTENCY MESSAGES ***
* * * W A R N I N G - MODEL * * * W2164-78: D/t ratio for the following pipe ID(s) is less than 20. The hoop stress equation may not be applicable for these pipe IDs as per B31.4. Use Model Result Option Y factor to control hoop stress equation. 4"C3E2B No error 1 Warning(s)
I am having the same exact issue.
Greetings,
I have uploaded a new Warning message here.
This should answer your questions on the issue. Let me know if you need further assistance.
Regards, Mike Dattilio Design Analysis Engineering Group Senior Analyst Bentley Systems Inc=============================================================================
Answer Verified By: Mike Dattilio
