Hello
Is anybody have calculated pipes with oil or other fluid which is heatnig by steam pipes (satelits)
Could sombody try to give me some issue.
Greetings Pawel,
I believe you are asking how to consider oil in a pipeline?
If yes, all you need to do is open a PipeID and update the Specific Gravity with that of oil. Note, that SG is based on water.
Regards, Mike Dattilio Design Analysis Engineering Group Senior Analyst Bentley Systems Inc=============================================================================
