Good day for all,
Autopipe shows the axes in all points in the model, How can i turn off the axes?
Greetings Edgar,
The easiest way of finding a specific command is to use Command Search Utility. In your case start typing "AXES"
Select a command from the list available to activate the command, or remember the location and manually activate the command.
In this case, disable the Local Axes command.
Regards, Mike Dattilio Design Analysis Engineering Group Senior Analyst Bentley Systems Inc=============================================================================
Answer Verified By: Mike Dattilio
