Interpretation of stresses at points
Greetings,
I have a quesion regarding stresses shown at points (code and general) of a model. I've been looking for an answer in AutoPipes Help but couldn't find one.
As far as I know, codes provide us with equations to evaluate stresses for straights and fittings.
AutoPipe shows calculated values of stresses at points which are located at joints between pipes and fittings.
Unless one inserts intermediate ones.
How does one interpret those values:
Which component do they refer to, if a point is located for example between a pipe and an elbow?
Kind regards,
Piotr Łukowicz
Proen
  • Thank you for your reply,
    I would like to clarify, though.
    Analyzing code stresses for the previosly mentioned pipe:
    I understand that point S20 F+ and S21 N- refer to the pipe between them.
    I assume that code (EN 13480 in this case) stresses for the combination GR + Max P{1} are calculated using:
    And are a single value for the entire pipe, as the code considers elements as a whole, unlike general stresses which can be found also for intermediate points.
    Am I right and if so, why are these values (shown above) slightly different? Is it because of the precision of AutoPipe calculations?
    Kind Regards,
    Piotrek
    Proen
  • Greetings Piotrek,
    What could be different between these 2 points that would affect the sustain calculations?
    With out being able to review the actual model, one should be able to assume that the following would be the same between the 2 end points of a bend component:
    • Pc = defined pressure
    • do =  Outside pipe dia
    • en = nominal thickness on drawings
    • i = Sif calculation
    • Z = section modulus for a pipe
    However the following could be different:
    • Ma = resultant moment from the sustained mechanical loads
    This would explain the difference in the reported results.
    Mike Dattilio
    Design Analysis Engineering Group
    Senior Analyst Bentley Systems Inc
    Answer Verified By: Mike Dattilio
  • Dzień dobry,
    Miałbym pytanie o to w jaki sposób te punkty, jeżeli wystąpią, będą oznaczone?
    Pozdrawiam,
    Piotr Łukowicz
  • Witam,
    Zostaną dodane do raportu pomiędzy punktami węzłowymi. Zapraszam do kontaktu bezpośrednio będzie szybciej łatwiej.
    In English on request of Mike: These points are added to the stress report if stress in between regular model nodes, if necessary only. Stress is calculated for interim points but isn't reported if it isn't necessary, i.e. isn't bigger than in boundary nodes of element.
    Best regards,
    Maciej Rydlewicz, PhD Eng.
    maciej.rydlewicz@softdesk.pl
    +48 512206994
