AutoPIPE Nozzle SIF
Found the Wiki below on how to calculate the fillet radius in AutoPIPE Vessel. Is this also applicable to Piping SIF tool in AutoPIPE Nozzle?
https://communities.bentley.com/products/pipe_stress_analysis/w/pipe_stress_analysis__wiki/20046/10-how-is-the-nozzle-fillet-radius-calculated-for-wrc-calculations-in-autopipe-vessel
Also, please let me know if my understanding is correct:
1. Fillet radius of mitre fillet weld should be zero.
2. Fillet radius more than zero is considered as concaved fillet weld.
  • Greetings,
    No, this is not applicable to AutoPIPE Nozzle. AutoPIPE Nozzle does not calculate a fillet radius. In AutoPIPE Nozzle the user is asked to enter a value of fillet radius e.g. 0.5” between the nozzle and vessel. The program will automatically calculate new stress concentration factors Kn (tensile) & Kb (bending) in accordance with WRC107 Appendix B. These factors on the code options dialog are only used for the Piping SIF calculation. If this box is 0 or blank then the Default values Kb=1 and Kn=1 are used. Note: Default stress concentration factors Kn (tensile) =1 & Kb (bending) = 1 may not be conservative in calculating piping SIF's. The stress concentration factors Kn (tensile) & Kb (bending) on the Factors Tab are applied to all stress combinations.
    Mike Dattilio
    Design Analysis Engineering Group
    Senior Analyst Bentley Systems Inc
  • Hi Mike,
    Yes, I need to manually input the fillet radius but can I use the same formula stated in Wiki in calculating the fillet radius? I only have the throat dimension.
    Albert
