We inserted a reference point, but can't find the results in the results grid, which also include comparing to the load allowables that we put in. Where are the results found?
Thank you,
Daniel Bittinat
Greetings Daniel,
At this time, Aug 2021, the results for reference points are only available in the models' input listing report,
Regards, Mike Dattilio Design Analysis Engineering Group Senior Analyst Bentley Systems Inc=============================================================================
Answer Verified By: Mike Dattilio
They can be found under
Result - Quick Reports - Output Report
Select Reference Loads
Greetings,
Correct!
