In the Autopipe output, where is the Pipe ID for each segment identified? It used to be identified in the data point listing (ver. 11). I can't find it in the ver. 15 output.
Hi Micheal,Yes you are right that 'Component Data Listing' report is not available in version 12.06.00.48. This report is now changed to number of tables for easy access of data.
You can check Pipe ID for each segment under 'Point Connectivity' Report.
Answer Verified By: Mike Dattilio
Where do I access the 'Point Connectivity' report?
User's should always update to the latest version to take advantage of fixes to known issues and added enhancements. It is not good business to use outdated software.
In this case, AutoPIPE 12.07.00.346 has been released, see release notes here.
To answer your question, the "Point connectivity" report is an model input sub-report. However, know that version 12.07.00.346 has added back the "Component Data Listing" sub report.
