hi,
I want to simulate the case of a high pressure gas that is vented to atmosphere when a vent valve opens suddenly. I know that at the instant the valve opens the flow will be high velocity, possibly choked at the exit of vent pipe and large forces generated on supports along the vent pipe. Is the Fluid Transient capable of this?
Greetings,
See AutoPIPE help modeling example:
Help > Contents> Contents Tab> Modeling Approaches> Example Systems> Steam Relief (Time History) Example.
Just note that this utility is for steam relief. Also see WKI here.
Regards, Mike Dattilio Design Analysis Engineering Group Senior Analyst Bentley Systems Inc=============================================================================
Answer Verified By: Mike Dattilio
