How to reduce .DAT file size
We have an ongoing project with a larger number of nodes and history.
 When we want to work a small section we copy  the model and delete the segments away form the area of interest.
The problem is the DAT file size remains very large even though there are only small number of  nodes left.
How can we reduce the file size?
We can copy the area interest  into a new model, but want to keep all the load combinations etc from the original model.
  • Greetings,
    Suggest opening a new mode with the same general model option settings. Then copy past eh section of piping of interest into the newly created model. Finally ensure the same settings for your analysis sets, run an analysis, and then import the CMB file using the Combination Options command, Import Combination File.
    Otherwise, you can try to round trip the model (see AutoPIPE wiki for steps).
    Mike Dattilio
    Design Analysis Engineering Group
    Senior Analyst Bentley Systems Inc
    Answer Verified By: Mike Dattilio
